I'm using a wall style I created which is a 3 1/2" stud wall with a 1" air gap and a 4" brick facade.
Strangely my windows don't all cut into the wall the same, (see attachment). Some cut through brick and others don't. They all did when I first inserted them.
I would prefer the window thickness to be only as thick as the 3 1/2' stud wall with only an opening cutting into the brick if anyone can advise me of a cool trick for that without having 2 walls and having to cut openings in the brick. Seems like wishful thinking on that one.
Thank You
