Thread: Revit-to-PDF Postscript Error
    2010-03
    Idaho Falls, ID
    19
    Default Revit-to-PDF Postscript Error
    One day I was able to print to PDF (using Adobe Acrobat 9 Pro & 10 Pro distiller) and the next day I wasn't. After a week and a half of research by myself and two of our IT folks, we uncovered the problem.
    The Error
    When I printed from Revit to PDF, I would get the following error message:
    [ ProductName: Distiller ]
    [ Error: undefinedresult; OffendingCommand: imageDistiller ]
    Stack:
    -dict-
    [ Flushing: rest of job (to end-of-file) will be ignored ]
    [ Warning: PostScript error. No PDF file produced. ]
    I could print to PDF from other applications (Word, etc), just not from Revit. The problem persisted over multiple machines and over multiple files.
    What Changed
    Our IT department pushed an Adobe update AND a Revit update. Not sure which (if either) of these changes caused the issue.
    The Solution
    In the Adobe print settings (Start > Printers and Faxes > Adobe PDF Properties) go to the Advanced tab and ensure that "Enable advanced printing features" is checked. Mine wasn't. Enabling it solved my print-to-PDF problem.
    I hope that this post saves somebody else the week-and-a-half headache it caused me.
    2012-03
    Default Re: Revit-to-PDF Postscript Error
    Hi I tried to fix the printer properties but it didn`t work for me...it stops saving as pdf..and i keep getting same error...can u please help..i really need to print as pdf??
    2007-03
    147
    Give DoPDF7 a try. It is free. I had this problem before.
    Read my blog:
    http://revit-it.blogspot.com/2010/08...g-to-pdfs.html
    HTH.
    2010-03
    Idaho Falls, ID
    19
    The other factor that may have caused my error, I recently discovered, was a graphic in my title block family. We placed the company logo in the title block as a jpeg image (because our logo has a graphical element and because we can't re-create our logo natively in Revit because Revit will not draw lines shorter than 1/32" in length). When I removed that jpeg logo from the title block family, my remaining print-to-PDF issues went away.
    2017-05
    Try the PDF recovery tool which is accepted widely. Read more about such tools from
  1. Revit Architecture 2008 Plotting- Non postscript drivers!!
    By mhaidar in forum Revit - Plotting/Printing/Exporting
    Last Post: 2007-09-11, 03:15 PM
  2. Using Postscript fonts in AutoCAD
    By kprater in forum AutoCAD General
    Last Post: 2005-12-09, 10:57 AM
  3. Postscript or Not?
    By andrewp in forum AutoCAD Plotting
    Last Post: 2005-10-04, 03:06 PM
  4. Want to get your Postscript Fonts into Revit?
    By Persistance in forum Revit Architecture - Tips & Tricks
    Last Post: 2004-04-23, 06:03 AM
