Thread: Ramps still don't play nice?
    2008-06
    Denver, CO
    179
    Default Ramps still don't play nice?
    I'm trying to utilize ramps in my below grade parking, but there are a few issues with them. I've done some searching on this, but all the comments come from 4-5 years ago so I was hoping they had been resolved by now, but I'm not figuring it out.
    1. Walls/columns can't attach to a bottom of a ramp (however they will to a sloped floor)
    2. Ramps will not join with slabs even with a constant material (in this case, concrete) This means linework tool is the only way to make it look right in sections.
    3. Can't place a spot elevation along a ramp at any point, even a defined edge. I need to place a reference plane and then put a spot elevation on that plane.
    Is using sloped floors the way to go? What's the point of ramps then? Any solutions? (i'm half frustrated, half curious)
    Thanks
    Ryan Taube LEED AP
    ___________________
    The Silent Type
    2015-12
    Miami, FL
    1,049
    Default Re: Ramps still don't play nice?
    1. To create walls below a ramp, the recommended method is to draw a wall, and then cut the wall with a void. If the ramp is curve, the void needs to be created a a swept blend between 2 profiles.
    2. Yes, ramps and stairs don't join to slabs. You might need to use Edit Cut Profile in section views.
    3. I learned this solution from my friend Jeff Hanson: From a plan view, first put a spot slope annotation on a slab (if the slab is flat it will read "[no slope]". Then move the slope annotation to the ramp, now it will report the slope of the ramp. http://www.revitforum.org/tutorials-...html#post35775
    2008-06
    Denver, CO
    179
    Thanks Alfredo, it's making more sense now. It seems that sloped floors are the way to go. Can you tell me, what's the point of ramps if you can't get spot elevations / get slope callouts / join with other elements with like materials?
    I've also seen that it's possible to create a Model Line that is aligned and locked with each break in the slab. However, the Spot Elevation doesn't seem to want to work with that either.
    Ryan Taube LEED AP
    ___________________
    The Silent Type
    2015-12
    Miami, FL
    1,049
    I don't know. Ramps just need to be improved by the factory. The fact that a spot slope annotation works when it is moved from a floor but not when it is applied directly on the ramp, looks like some things about ramps are still half baked.
    Member thorbjorn's Avatar
    2009-02
    Stockholm
    5
    Quote Originally Posted by rtaube View Post
    I put a slope annotation in a top-orientated 3D view and then I cut and paste "same place" in my normal plan view - then it reads the slope just fine. Works for spot elevations as well.
    That move method sounded nice but I didn't get it to work.
  1. Revit 2012 won't play nice with ACAD 2013 files
    By stu1037 in forum Revit - Platform
    Last Post: 2013-02-26, 04:57 PM
  2. TrueView 09 won't play nice with AutoCAD 2009
    By mpeterson79 in forum DWG TrueView - General
    Last Post: 2009-04-28, 02:30 AM
  3. Point Parameters don't play nice with Flip
    By mockdeep in forum Dynamic Blocks - Technical
    Last Post: 2008-08-21, 07:32 PM
  4. 2008 doesn't play nice?
    By sjansen.147364 in forum AutoCAD General
    Last Post: 2007-12-19, 03:20 PM
  5. 2 civil.cui files and only one will play nice
    By m.vanitallie in forum AutoCAD CUI Menus
    Last Post: 2007-08-22, 11:22 PM
