Thread: Room Names Not Showing
    2010-05
    85
    Default Room Names Not Showing
    I use that external utility for room names. I have created the spaces automatically then used this tool to insert the room names. Everything looks fine on my power plans but for some reasons the room names are not showing on the lighting plans. Any ideas?
    Kevin L. Yingling, PE
    Principal
    Innovative Electrical Systems Inc
    www.iesystems-inc.com
    I could stop if I wanted to CADastrophe's Avatar
    2012-01
    Site of the next CADaclysm
    386
    Default Re: Room Names Not Showing
    If the Spaces are not visible (with them turned on in V/G), ensure that the Cut Plane is cutting through the Spaces, as they will not show unless this is so. If the Cut Plane on you Lighting Plan is at 0", change it to 1/2" (someting higher than 0") so that it slices through the bottom of the Spaces.
    2008-02
    Austin, TX
    175
    Obvious question, but have you placed space tags in your lighting plan? They are view dependent.
    2009-07
    Seattle, WA
    73
    Also, room/space tags are annotations so they show up in only one view. So when you create spaces automatically, the tags will show up but only for the view you were in when you created spaces. What I'll do is create spaces, run the space naming utility, then select all the tags and copy to clipboard, then paste them to the other plan views.
  1. Revit 2012 can you Delete Unused Room Names & Department Names
    By billy007nh in forum Revit Architecture - General
    Last Post: 2012-12-03, 04:43 PM
  2. 2012: Showing Room names from Linked Architectural
    By ftonelli in forum Revit MEP - General
    Last Post: 2011-10-25, 02:56 PM
  3. Some room names showing up as "unoccupied"
    By musicjunkie300 in forum Revit MEP - General
    Last Post: 2011-01-31, 04:24 PM
  4. Replies: 35
    Last Post: 2009-08-18, 07:52 PM
  5. Help: Convert Space names to Room Names??
    By stykface in forum Revit MEP - General
    Last Post: 2009-06-30, 02:47 PM
