Thread: Surface Comparison Volumes
    2003-03
    135
    Default Surface Comparison Volumes
    I was wondering if there was a way to put a table on my drawing showing the total cut and fill for the volume surface I've created? Then as I make adjustments to either surface, the table would update automatically.
    Arizona
    2,337
    Default Re: Surface Comparison Volumes
    Go to Annotate tab
    Add Table
    Total Volume Table
    you will ned to create a sample line group
    2015-10
    Texas
    66
    you can used the new volume dashboard extension. If you dont have it ask your cad manager if he can download it from the subscription website.
    tony
    CAD Manager
    www.tonyscivil3dworld.blogspot.com
    2003-03
    135
    Thanks for the info. It was very helpful. Now I have another question. Has anyone created a surface style for volume where you show cut/fill contours in different colors? Trying to see how to create a style, but can't get it figured out. Thanks!
    Arizona
    2,337
    Yes, I have a tutorial for doing just that on my webpage.
    The short answer...
    Go to Surface Style turn ON th USER contours
    Select the Surface
    Got to surface Properties
    go to Summay tab to find out what the total elevation rang is between Min and Max
    Go to Analyze Tab
    Select Elevation as the Type of analysis
    Enter N+1 number of elevations
    Hit the Arrow to perform the analysis
    Go down below and Set the elevation ranges and colors you want to describe them.
    Hit Apply
    Hit OK
    Have a Nive Day!
  1. Cut Fill Volumes surface ranges
    By Statler in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2012-08-17, 12:44 PM
  2. Fix Block comparison
    By limartin in forum AutoLISP
    Last Post: 2010-09-20, 06:02 PM
  3. New PC comparison
    By DoTheBIM in forum Revit - Hardware & Operating Systems
    Last Post: 2008-07-30, 02:13 PM
  4. Using ShapeTrapezoidal to create surface and volumes
    By patrick.ericson in forum AutoCAD Civil 3D - Corridors
    Last Post: 2008-02-08, 06:52 AM
  5. Two Surface Volumes By Station
    By Spokes in forum Land Desktop - General
    Last Post: 2006-02-10, 08:27 PM
