Thread: Circuiting is too time consuming
    2004-06
    IL
    18
    Default Circuiting is too time consuming
    There is too much clicking, moving mouse, clicking, moving mouse going on.
    We need a command line prompt for circuiting.
    My old blocks had a cct attribute and a panelboard tag.
    I could type CCT and select as many blocks as I wanted and then type the circuit number I wanted them to be.
    I could type PNL and select as many blocks as I wanted and then type the panelboard name I wanted them to be.
    It was very fast. I could use both hands for input.
    My excel VBA would then grab that data and fill out my excel pnlbd schedule.
    Granted with MEP there would need some checking for if that circuit number exists on that panelboard. But it could default to the pnlbd the device is currently connected to (or the majority are connected to), then you could change that if needed. Then you type the cct number and could have a ? for listing available ccts on that pnlbd. If the cct does not exist, it could ask if you want to create it, or simply say, cct is not available.
    Forum Manager, Administrator Ed Jobe's Avatar
    Turlock, CA
    4,776
    Default Re: Circuiting is too time consuming
    Are you asking a question? Or is this a wishlist item?
    C:> ED WORKING....
  1. re-circuiting issue
    By cookie in forum Revit MEP - General
    Last Post: 2010-03-09, 01:28 PM
  2. Circuiting
    By wags5116 in forum Revit MEP - General
    Last Post: 2010-02-24, 01:41 PM
  3. Circuiting Error
    By troy.crandell635379 in forum Revit MEP - General
    Last Post: 2010-01-19, 07:12 PM
