Looking for a lisp that will draw a center line after selecting 2 points and places the CL symbol using Romans font.
Mac
What about a linetype?Code:*CL,---- CL ---- - ---- CL ---- - ---- CL ---- A,6.6,-.06,["C",STANDARD,S=.1,R=0.0,X=-0.04,Y=-0.025],-.01,["L",STANDARD,S=.1,R=0.0,X=-0.01,Y=-.065],-.07,6.6,-.05,.07,-.05
Tom Beauford P.S.M. - Civil 2013 on Windows 7 Pro
Design Analysis - Leon County Public Works/Engineering
Ph# (850)606-1516
I interpreted the OP very differently... Perhaps the OP can post a picture of specifically what is being requested?
"Potential has a shelf life." - Margaret Atwood
I interpreted select 2 points to get proper rotation, and place a centerline symbol adjacent to the line. I'll await further pictorial information.
Christopher T. Cowgill, P.E.WIGHTMAN & ASSOCIATES, INC.
ENGINEERING <> SURVEYING <> ARCHITECTURE
AutoDesk Infrastructure Design Suite Premium 2013 x64
Windows 7 Pro x64
Sorry friends I know nothing about labeling lines
maybe it will be the answer
~'J'~Code:(defun C:test(/ ang mp p1 p2) ; Convert value in radians to degrees (defun rtd (a) (* 180.0 (/ a pi)) ) (if (and (setq p1 (getpoint "\nStart point: ")) (setq p2 (getpoint p1 "\nEnd point: "))) (progn ;; align text (setq ang (angle p1 p2) ang (cond ((< (/ pi 2) ang (* pi 1.5)) (+ pi ang)) (T ang) ) ang (rtd ang) ) (setq mp (mapcar '(lambda(a b) (/ (+ a b) 2.0)) p1 p2)) (command "._line" "_non" p1 "_non" p2 "") (command "._chprop" "L" "" "LT" "Center" "")));<-- cnange linetype here (command "._mtext" "_non" mp "_J" "_MC" "R" (rtos ang) "_W" "0" "\\U+2104" "") (command "._chprop" "L" "" "Color" "1" "" );<-- cnange color here or remove this line (princ) )
Last edited by fixo; 2012-02-17 at 11:06 PM. Reason: extrafluous double quotes removed
"The whole problem with the world is that fools and fanatics are always
so certain of themselves, and wiser people so full of doubts."
Bertrand Russell
You're quite welcome, Steve
I removed double quotes in the code above
Cheers
~'J'~
Bertrand Russell
ccowgill has the interpretation correct,
now that I think about it, after selecting each point it would be nice to be able to extend the line type if desired. I could make a dynamic block, but it seems a lisp would be more efficient. her is a dwg with the center line and notation.
regards
Mac
Gave this a test drive, very nice!
how can I get the text to be at the end of the line and text rotation always same as line?
Mac
will be back in tomorrow only
Bertrand Russell
