Results 1 to 6 of 6
Thread: Flipping Text Attributes
    2005-02
    Michigan
    23
    Default Flipping Text Attributes
    Is there a way to flip text attributes in a dynamic block? I need the ability to flip text horizontal and vertical. I will attach the block. Any help would be appreciated.
    I could stop if I wanted to clshade's Avatar
    2009-01
    B5
    465
    Default Re: Flipping Text Attributes
    Couple questions:
    Is this a new block or and old one you are adding Dynamic Properties to?
    Would you want the Attribs to be relative to where they are or do you want to Flip the whole group of entities?
    For the first question the Attribs must be locked. Usually when an Attrib is created in a DynBlk it defaults to Locked which is why I ask if this is an old block.
    If this is an old block it may be easier to just delete the Attribs and recreate. Sometimes changing these to Locked still does not produce the desired results.
    As for the second question we would need to know what you want Flipped to offer guidance.
    Charles Shade LT 2013
    www.cshadedesign.com
    2005-02
    Michigan
    23
    This is a new block created in Autocad 2012. I would like to flip it based on the center of the circle. Both horizontally and vertically. Each set of text could have the possibility of 4 positions.
    Sorry for not posting enough information earlier.
    2009-01
    B5
    465
    Hope I did not futz with it too much and get your Vis states off.
    2005-02
    Michigan
    23
    How were you able to select the attributes to flip them? Thanks, this is what I needed.
    2009-01
    B5
    465
    Attributes must be Locked in a DynBlk.
    Look in the parameter list for Attribs and at the bottom is Locked(Tag, Prompt, Default...Locked)
  1. Spot Elevation Text Flipping
    By emily.clark in forum Revit Architecture - General
    Last Post: 2010-08-13, 04:19 PM
  2. Text or Attributes
    By ablanchard in forum AutoCAD Customization
    Last Post: 2008-01-19, 06:37 PM
  3. Prevent Text from Flipping when block is Flipped
    By TerribleTim in forum Dynamic Blocks - Technical
    Last Post: 2007-05-09, 09:22 PM
  4. Mirror Xrefs without flipping text
    By Shaji Thankachan in forum AutoCAD General
    Last Post: 2007-01-09, 09:29 AM
  5. Flipping Attributes in Dynamic Blocks
    By lwhite.49103 in forum Dynamic Blocks - Technical
    Last Post: 2006-04-26, 05:24 PM
