Is there a way to flip text attributes in a dynamic block? I need the ability to flip text horizontal and vertical. I will attach the block. Any help would be appreciated.
Couple questions:
Is this a new block or and old one you are adding Dynamic Properties to?
Would you want the Attribs to be relative to where they are or do you want to Flip the whole group of entities?
For the first question the Attribs must be locked. Usually when an Attrib is created in a DynBlk it defaults to Locked which is why I ask if this is an old block.
If this is an old block it may be easier to just delete the Attribs and recreate. Sometimes changing these to Locked still does not produce the desired results.
As for the second question we would need to know what you want Flipped to offer guidance.
Charles Shade LT 2013
www.cshadedesign.com
This is a new block created in Autocad 2012. I would like to flip it based on the center of the circle. Both horizontally and vertically. Each set of text could have the possibility of 4 positions.
Sorry for not posting enough information earlier.
Hope I did not futz with it too much and get your Vis states off.
How were you able to select the attributes to flip them? Thanks, this is what I needed.
Attributes must be Locked in a DynBlk.
Look in the parameter list for Attribs and at the bottom is Locked(Tag, Prompt, Default...Locked)
