Thread: Drawing will not open
    2007-09
    3
    Default Drawing will not open
    I have a drawing that won't open. I figured out that the problem is with one of the xrefs, so I tried to go into the xref and that won't open either. I ran recover on both drawings and it won't open. Both times AutoCAD just freezes up. I have no idea where to go from here. Any suggestions?
    It's weird because I was working on it earlier today and it was fine.
    0,0,0 The Origin
    8,026
    Default Re: Drawing will not open
    Hi, welcome to AUGI.
    Can you post the xreffed file here?
    John B
    "With or without religion, you would have good people doing good things and evil people doing evil things. But for good people to do evil things, that takes religion." - Steven Weinberg.
    2007-09
    3
    Here it is.
    Cairo - no, not Illinois
    2,715
    What version are you using? I was able to use Recover in Map3D 2012 amd open the file. Recover advised 1 object erased.
    Opening also indicated that the DWG was not from Autodesk, and has AEC objects in it. If I use _aecexporttoautod, I can dumb it down and save back to a lower version.
    A suggestion to minimize future problems. Do not use bang characters, spaces, or punctuation in layer names, eg. exclamation points, periods, etc. life will be smoother if you limit layer names to alphanumeric characters, hyphens, and underscores. so your !111 WINDOWS should be _111-WINDOWS
    more reliable overall if you follow the KISS principle.
    Officially Awesome
    2007-09
    3
    I'm using autocad 2007. I was able to have someone else open it and fix it.
    I don't usually use complicated layer names. This drawing was sent to me with those it in. But from now on I will be more careful about erasing them right away.
    Thanks so much!
  1. Replies: 2
    Last Post: 2011-02-10, 12:11 AM
  2. Replies: 2
    Last Post: 2006-05-10, 06:38 PM
  3. Replies: 2
    Last Post: 2006-05-02, 04:41 PM
  4. Replies: 8
    Last Post: 2006-05-01, 06:39 PM
Tags for this Thread
