Thread: Revit plan callout
    2011-03
    3
    Default Revit plan callout
    I am generating plan callouts in Revit Architecture 2012 and the main (parent) plan shows the callout boundary, but not the bubble that references to the plot sheet where the callout is actually shown. In the Properties panel of the parent plan, the sheet and number of the plan callout is shown correctly, but the text is ghosted. What is the setting required to show the reference bubble? Thanks for your help.
    2006-10
    236
    Default Re: Revit plan callout
    If you select the callout and edit the type properties - does it have a "Callout Tag" listed? Does that callout tag have a callout head listed? Or is it set to "<none>"?
  1. 2013: plan callout scale
    By clintonc in forum Revit - Platform
    Last Post: 2012-10-23, 06:47 PM
  2. 2012: callout reference - not showing the plan
    By utakecare2003 in forum Revit Architecture - General
    Last Post: 2012-10-12, 06:19 PM
  3. Revit 2010 - Material Tag Not Showing in Floor Plan Callout
    By ruthellenwilliams in forum Revit Architecture - General
    Last Post: 2009-07-09, 04:37 PM
  4. Only one plan callout style possible? What's up with that?
    By Wes Macaulay in forum Revit Architecture - General
    Last Post: 2009-02-15, 03:33 AM
  5. plan callout issue
    By Chirag Mistry in forum Revit Architecture - General
    Last Post: 2007-07-18, 05:33 PM
