Results 1 to 9 of 9
Thread: how to make twisted solid cube in autocad?
    2012-03
    3
    Question how to make twisted solid cube in autocad?
    can any one help me out to make twisted solid cube in autocad?
    I could stop if I wanted to Norton_cad's Avatar
    2007-05
    Bardwell Valley, Sydney, Australia
    433
    Default Re: how to make twisted solid cube in autocad?
    Draw a closed polyline of a square, copy and rotate it to the deired angle, move this new polyline up in the Z plane; Set the system variables of Ruletab1 & 2 to a higher level than default to say 128 for each; Then use the Rulesurf command on the exploded polylines. Also Solidify commands are available, but both methods produce varying accuracy on the curves produced. I think that Nurbs algorithums really didn't apply to pre 2006. Post 2006 the new Loft command.
    Ohm's Law - Electricity follows the path of least resistance.
    Regards,
    Mark Norton,
    2012-03
    3
    Quote Originally Posted by Norton_cad View Post
    thanks.
    i will try this
    2012-03
    3
    Smile Re: how to make twisted solid cube in autocad?
    i tried as you suggested and made twisted object. but this is not solid. if i can make soild like as attached here it will be good to know its "massprop".
    i also tried to use utility to make mashes to solid but that is keeping object open from ends.
    All AUGI, all the time arshiel88's Avatar
    2005-02
    Off the Grid
    548
    The other command mentioned, "LOFT", will create a 3D solid object.
    Shielbern Bolalin
    Architectural 3D Renderer
    “A clever person solves a problem. A wise person avoids it.”
    1879-1955
    2007-05
    433
    Quote Originally Posted by sanjay9172385130 View Post
    Create a rulesurf for the top & bottom, then use your utility, or try the "Solidify" command.
    It's allot easier to do this in 2007 upwards with the Loft command though, What release are you working with?
    Regards,
    Mark Norton,
    2008-05
    2
    why not just draw a rectangle the size you want and then draw a helix the size and twist you want and sweep the rec.along its path?
    Williamsport, PA
    606
    Quote Originally Posted by arshiel88 View Post
    Wrong forum. Loft did not exist in 2006 and earlier.
    Could do it in FREE Inventor Fusion http://labs.autodesk.com
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    AU 2007 Avatech Altogether Smarter Inventor On-line Challenge 1st Place
    Autodesk Inventor Certified Expert
    Certified SolidWorks Professional
    Williamsport, PA
    Williamsport, PA
    606
    Quote Originally Posted by tintom606 View Post
    Can you demonstrate how to make a Helix and Sweep in AutoCAD 2006 or earlier. This forum is for earlier releases of AutoCAD. Helix and Sweep command were added in 2007. I think this information was provided early on in this thread.
    Williamsport, PA
  1. make a surface into a 3d solid
    By jcushing in forum AutoCAD Civil 3D - General
    Last Post: 2011-05-09, 04:20 PM
  2. Revit Stairs - How to make solid balusters?
    By samov in forum Revit Architecture - General
    Last Post: 2010-01-05, 03:24 PM
  3. 3D regions join to make solid
    By ericheatherh in forum AutoCAD 3D (2007 and above)
    Last Post: 2009-02-17, 09:12 AM
  4. AutoCAD 2008 - Make a hole in a Solid
    By kwong in forum AutoCAD 3D (2007 and above)
    Last Post: 2007-05-15, 11:59 AM
  5. Importing Autocad Fill (Solid or Solid Hatch)
    By Jit in forum Revit Architecture - General
    Last Post: 2004-04-20, 12:51 AM
Tags for this Thread
