To create a wood frame family, I need to precisely notch the timbers.
To control the dimensions with parameters, length, width, depth, there is no problem.
And then flexing the dimensions works out fine.
Now when I want to make notches in the extrude profile and control the sketch
with parameters, I get a "constraints are not satisfied" message on attemping to flex
the parameters. In this case setting 'a = 27' in the parameters properties dialog box.
And the only option offered is to remove the constraints. What should I be doing?
See sketch for dimension clarification.
Load attached .rfa file to test flexing of parameters 'a' and 'b'.
