Thread: Rectangular column with rounded ends
    100 Club swmarais's Avatar
    2009-06
    Cape Town, South Africa
    109
    Default Rectangular column with rounded ends
    How do I go about creating a rectangular column with the short ends being half circles?
    2009-06
    109
    Default Re: Rectangular column with rounded ends
    I have managed to create the column family.
    The cross section behaves as required, but I am struggling to get the height to work correctly
    The height seems fixed as per the family extrusion length.
    I do not see any additional parameters in the native column families.
    How do I fix this?
    2011-10
    I'm not sure what went wrong in your rfa-file, but it doesn't connect to the upper level.
    I made new Metric Column Family and locked all sides to the corresponded referenceplanes. It connected without problems. See attachment. Hope it helps.
    2009-06
    109
    Quote Originally Posted by FifT2 View Post
    Thanks for the help... I also found it strange.
    Eventually I used a workaround in the familiy, i.e. a 0 dimension between the extrusion top/base and the relevant reference plane
  1. Non-rounded line ends
    By rickbowles1 in forum Revit Architecture - General
    Last Post: 2012-06-27, 12:43 AM
  2. Creating rounded wall ends..
    By nyndat533844 in forum Revit - Student Support
    Last Post: 2011-03-25, 05:13 PM
  3. Create a countertop with OPTION for rounded ends?
    By patricks in forum Revit Architecture - Families
    Last Post: 2010-04-16, 08:26 PM
  4. rounded corners
    By BCrouse in forum Style Management
    Last Post: 2004-08-05, 04:46 PM
Tags for this Thread
