Ok, so I just ran across this issue today, and trying to figure out if its a Revit issue or an issue with my template (I'm leaning towards Revit ). Ok, so we have a switchboard that uses breakers (so perhaps it would be better to call it a distribution board?). In the switchboard schedule "General Settings", I have the "Number of Slots Shown" set to "Variable based on max number of 1-pole breakers". In the "Circuits Table", I have the format for loads set to "Separate Phase Loads per Circuit", although I doubt it matters.
So the issue becomes, Revit treats each circuit as a 3-pole load (ie, Circuit 1 has phases A/B/C, Circuit 2 has phases A/B/C, etc), but it sizes the panel based on 1-pole loads. If I want a panel schedule to show 20 breakers (loads), in my family, I would set max #1 pole breakers to 60 (20 3-pole breakers), but this sets the switchboard schedule to 60 loads. If I set max #1 pole breakers to 20, the schedule displays correctly, but then I can only add 6 3-pole loads, and 2 1-pole loads. So the schedule layout isn't working with what is actually displayed (if that makes sense).
Eric Grey, where are you to explain this one?
