Results 1 to 10 of 10
Thread: Printing pdf's
    2004-05
    Custer, Washington
    77
    Default Printing pdf's
    O.K. this is crazy. Why is it when I send a pdf that I've received from arch, struct,
    whoever, the pdf is 723kb & when it reaches the plotter/printer it becomes 31.5 MB.
    It doesn't happen all the time but it seem more often now.
    Certifiable AUGI Addict Wanderer's Avatar
    2001-12
    St. Louis
    4,260
    Default Re: Printing pdf's
    Quote Originally Posted by kimlance View Post
    Hmm, maybe some details on your setup could help?
    What type of plotter? Are you using a print server?
    Do you know if the origins of the pdfs are the same (built in autocad driver or acrobat or bluebeam, etc?)?
    Melanie Perry @MistresDorkness
    Facilities CAD Management (FM - MEP/FP)
    Technical Editor
    Revit MEP 2013 Suite
    not all who wander are lost
    2004-05
    Custer, Washington
    77
    Plotter is a HP Designjet 1050c Plus, printer is a HP Laserjet CA111A.
    Plotting thru a server. I'm quite certain they are created through autocad. The pdf's are coming from different diciplines, Arch Struct, Mech. Like I said this doesn't happen all the time, I'm wondering if it's how they are creating them.
    I could stop if I wanted to Liamnacuac's Avatar
    2005-12
    441
    What resolution are you plotting to? Adobe will default to 1200 DPI
    2004-05
    Custer, Washington
    77
    I've gone thru all the setting to make sure they are correct and have the resolution set down to 300dpi.
    Cairo - no, not Illinois
    2,729
    ... the pdf is 723kb & when it reaches the plotter/printer it becomes 31.5 MB...
    Where are you seeing the size ballon? in the plotter queue? when you save the dwg file? or????
    If it's just in the queue, it matters not. plot file size is not closely related to file size. And, both the devices you mentioned are not using postscript or pdf natively, so there's a conversion that has to happen from 'pdf' to hpgl or pcl. Not the most efficient process size-wise, but in that instance it doesn't need to be.
    Officially Awesome
    2004-05
    Custer, Washington
    77
    cadtag,
    Thanks for the feed back. Yes it increases when it is sent to the plotter &/or printer queue. It's bothersom because the files are so big that I can only send one drawing over at a time otherwise it overloads the plotter/printer capacity. Have you experienced this also with the increase in flie size?
    I could stop if I wanted to Mamma Jamma's Avatar
    Massachusetts
    336
    Within the Adobe (or whatever program) dialogue box, you should be able to go to properties (maybe "advanced" tab/button somwhere) and tell the program to "Print as image". If you can find that, I think it might fix it for you.
    Mamma Jamma
    "Normal is an illusion. What is normal for the spider is chaos for the fly"
    Morticia Addams
    AUGI Addict cdatechguy's Avatar
    2004-02
    CdA, ID
    1,378
    As long as it plots I would not worry about it....
    A simple word document of 20k can inflate to 5-10mb when sent to the printer...
    Michael "MP" Patrick
    "I never make stupid mistakes. Only very, very clever ones."
    2004-05
    Custer, Washington
    77
    Mamma Jamma,
    I swore I tried that yesturday when I was playing with the settings. Thanks for pointing me back in the right direction, it worked. Thanks for everyones response.
  1. 2000: Printing
    By peterhopf198078 in forum AutoCAD General
    Last Post: 2012-01-03, 12:19 PM
  2. 2012: Xrefs not printing or printing in light gray
    By bap020799 in forum AutoCAD Plotting
    Last Post: 2011-08-10, 07:28 PM
  3. Printing
    By cintyarodas in forum Revit - Student Support
    Last Post: 2008-04-03, 01:22 AM
  4. Printing Hp Laserjet 5000- Customer Logo not printing solid
    By thomas.huckabee in forum AutoCAD Plotting
    Last Post: 2005-05-26, 08:42 PM
