Thread: Request lisp Help
    2008-11
    Default Request lisp Help
    Hello Everyone,
    I have done simple lisp before but I think I stepped in over my head with this one.
    I want to change to correct layer, attach xref, change back to previous layer then zoom extents. I got the following code:
    ; This function attaches xref on correct layer
    ( DEFUN C:XRA ()
    ;(SETQ CURRENTLAYER (GETVAR "CLAYER"))
    (SETVAR "CLAYER" "g-anno-refr")
    (initdia)
    (command "._xref")
    ;(SETVAR "CLAYER" CURRENTLAYER)
    setting the layer is not setup to function because it wasn't working.
    I had some other code in but it wasn't working at all, so I removed it.
    Any help greatly appreciated.
    Jim C.
    AutoCad Civil 3D 2011
    2002-08
    101
    Default Re: Request lisp Help
    Hello,
    You must achieve the command before to continue (not necessary if the command is the last call of the code)
    For this use the status of the variable CMDACTIVE is the best.
    For exemple change:
    (command "._xref")
    to:
    (command "_.xref"
    (while (not (zerop (getvar "cmdactive")))
    (command pause)
    2008-11
    Here is what I tried and still not working....
    (DEFUN C:XRAt ()
    (initdia)
    (command "_.xref"
    (command pause)
    Thanks Bruno for the help....
    Jim
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    6,836
    Quote Originally Posted by jwchambers View Post
    (DEFUN C:XRAt ()
    (initdia)
    (command "_.xref"
    (command pause)
    Jim
    I know it may be a bit complex, but I would recommend using Command Reactors for this task. You can look at this example.
    2008-11
    Thanks Opie. That is way over my head at this point. Will have a go when I get some free time.
    Jim
  1. Request for a Lisp Routine
    By sorman in forum AutoLISP
    Last Post: 2010-01-04, 07:18 PM
  2. Lisp Request
    By sadikozer34 in forum AutoLISP
    Last Post: 2009-09-06, 08:49 AM
  3. Layer display lisp request..........
    By dave3409 in forum AutoLISP
    Last Post: 2007-10-01, 03:25 PM
  4. Request for a simple lisp routine
    By BM75 in forum AutoLISP
    Last Post: 2005-11-23, 09:27 PM
