Thread: trueType font resolution
    2010-10
    5
    Default trueType font resolution
    Hi all, I was wondering if there is a way to improve the resolution I obtain when I explode certain true type fonts in my .dxf drawing.
    Someone showed me how to exploded them with the express/text/explode text command, but when I do, they come back with a lot of large line segments that look pretty bad. i was then shown how to covert them to regions, and union them to join all the segments, but this doesn't help the resolution. Does anyone have a suggestioin on how to make them more curvy?
    Pat
    Cairo - no, not Illinois
    2,714
    Default Re: trueType font resolution
    you could try to perform a WMFOUT and WMFIN, zoom in pretty close though beforehand.
    also, see http://forums.autodesk.com/t5/AutoCA...D/td-p/3067564
    However, results may not be up to what you need, and may require substantial cleanup. it will be a start though.
    Officially Awesome
    All AUGI, all the time arshiel88's Avatar
    2005-02
    Off the Grid
    548
    Setup a DXB File printer. Print the text to a dxb file. Make sure to set TEXTFILL to 0 so that you'll only have the outlines. Then import back by DXBIN command. You'll have a segmented, but finer outline, almost no cleanups necessary.
    If you are not satisfied with this, the best way I know is to do the text in Illustrator, then generate the outlines there and export to AutoCAD. You'll have a nice and smooth splines, not segmented lines.
    Shielbern Bolalin
    Architectural 3D Renderer
    “A clever person solves a problem. A wise person avoids it.”
    1879-1955
    2010-10
    5
    Thanks all for the help. I had the most success withthe DXB file printing. This smoothed the text out quite a bit. I don't have Illustrator (I am guessing this is Adobe Illustrator) so I was not able to try this idea, but I think the results I am getting from the DXB file format will work okay. Thanks again all for your help!
    Pat
  1. 2009: TrueType Font Display Problem
    By derek.96018 in forum AutoCAD Customization
    Last Post: 2012-01-11, 07:55 PM
  2. TrueType Fonts issue
    By lenagagnon in forum AutoCAD General
    Last Post: 2008-11-11, 04:29 AM
  3. Truetype font problems
    By Coolmo in forum AutoCAD General
    Last Post: 2008-01-29, 12:12 PM
  4. TrueType Font showing incorrectly.
    By macphail in forum AutoCAD General
    Last Post: 2007-03-29, 10:41 PM
  5. Problem with Custom TrueType Font
    By n.curtin in forum AutoCAD LT - General
    Last Post: 2005-07-14, 02:16 PM
Tags for this Thread
