I'm trying to duplicate a CMU wall, and add rigid insulboard.
I know that I can just use the insulation tool to insulate exterior walls, but I need more flexibility in applying materials to the finished walls... so...
I took an "Exterior CMU Uninsulated" wall, duplicated it, renamed "Exterior CMU Insulated", and went in to edit the layers (to add a layer of insulboard).
I added a "Thermal/Air layer", and applied thickness, but I don't know how to add properties to it (R value, specifically). If "rigid insulation board" were an option when I open the Materials dialog, I'm sure it would contain R values, but I can't see it listed. Is there any way I can load an existing "insulation board" into my new wall family (under "Type Properties - Structure - Edit" ) that already has R-value/thickness parameters included already?
Thanks!
