Ok, we skipped MEP 2011 and have moved on to 2012... Back in 2010 one could define elbow angles in the "add conduits" dialog box, layout method. I.e. OTB has 15, 30, 45, 60, 90 degrees and we'd add 5, 10 and 22.5 degrees.
Moving on to 2012, the dialog box has since gone away (left in 2011) and now all conduit properties are modified either at the command line or in the Properties dialog box (if it is undocked). Under routing there is still a bend angle drop down, says either "values from catalog" or the standard bends as noted above...
The question is, where does one now add custom bends? Is there a table or catalog(s)? We've tried to add custom bends here (in properties), but they are not remembered and this is a problem when MEP is looking for an automatic solution with regards to offsets or kicks in conduit.
Any help is greatly appreciated.
Scott
