Is this actually possible.
I had a 200mm RC slab, flat. I had placed mesh and rebars in it with no problem.
I then had to put a split line down the middle of the slab to have a small fall from the centre out on both sides.
I have tried placing mesh, it only seems to be placed level, so totally outside the slab.
I then tried with rebar, it places it on the correct slope, for the first part then continues up the slope into thin air.
I have another RC ramp, tried place area steel in this too, once again gets placed horizontal. So set the work plane to the sloping slab, info box pops up say you can not view work plane in this view. Revit satrs to send you in a circle.
Correct me if Iam wrong, but you don't place mesh by sketching on a section.
This work plane thing seems to have me stumped.
So how do you place steel/mesh?????????????
