Thread: 3D Display of Opening Endcaps
    2002-05
    172
    Default 3D Display of Opening Endcaps
    Is there a setting that gets the opening endcaps to display in 3D? The end of wall displays correctly, but the openings all show with a Standard endcap (the edges of all components exposed). The opening endcap styles allow the head, jamb, and sill to have different endcaps assigned, so I assume they must display differently, but they still all look the same. The plan display is fine. Thanks.
    Moderator arcadia_x27's Avatar
    2015-10
    The 'Mill,Moncton, NB, Canada
    516
    Default Re: 3D Display of Opening Endcaps
    Ive never noticed how the head, jamb and sill are affected in our drawings here becasue we just use the standard endcaps, we do however use custom endcaps for the ends of our walls and they all display properly in 3D. Perhaps is it a setting in your display reps or properities of the wall style youre using.
    2003-03
    Philadelphia, PA
    2,392
    Assuming that you are using the out-of-the-box display system, for the most part, you will want to edit the Model Display Representation for Walls and, on the Other tab, check the Display Opening Endcaps toggle. [It is the only one in ADT 2004.]
    2002-05
    172
    Thanks for the help. In following up on your suggestions, I found that in 2005, there is an override in the Options/AEC Object Settings tab for opening endcap display.
  1. Endcaps Help!
    By abakwansema in forum ACA General
    Last Post: 2008-08-27, 01:43 AM
  2. ADT2006 -Wall opening endcaps
    By jswan.83519 in forum Style Management
    Last Post: 2007-03-06, 12:42 PM
  3. Opening in walls don't display what's behind them.
    By hdjohnson in forum Revit Architecture - General
    Last Post: 2006-05-10, 09:34 PM
  4. Archtop Opening Cut Display
    By Rhythmick in forum Revit Architecture - General
    Last Post: 2005-04-07, 05:27 PM
  5. Opening endcaps
    By Chuckyd67 in forum ACA General
    Last Post: 2004-10-15, 04:38 PM
