Um...If I deleted a mass that a curtain system was based on...Is there a way to edit the profile of the system, or recreate it magically?
Thanks!
Thanks!
Nope!
You must try to get it back. If you have a backup or Shadow Copies enabled in Windows,
you can go back into an older file before the Mass was deleted, open the previous version,
and copy it into your file.
Masses are turned off by default in all views, so double check and confirm that the Mass was actually deleted and not just turned off.
