Thread: Cannot undo hide
    AUGI Addict MikeJarosz's Avatar
    2003-09
    New York NY
    1,004
    Default Cannot undo hide
    I'm working on an elevation. I hide an object using the eyelass icon so I can work behind it. Later I hide another object in the same view in the same way. When I try to unhide the two objects, only one restores. What's up?
    Both objects appear properly in other views
    "everything you know is wrong...." -FST
    2003-04
    Irvine, CA
    6,770
    Default Re: Cannot undo hide
    You didn't accidentally chose the Apply changes to view option at some point? I've done that a couple times while in a rush and ended up wondering the same thing. Do you see the missing element(s) if you use the Reveal Hidden Elements feature (light bulb near the sunglasses). If so then you did...
    2003-09
    New York NY
    1,004
    The lightbulb worked. The hidden elements were visible and a click brought up 'unhide in view'
    Got scared for a minute.........
  1. Can't Undo
    By the_gibson in forum Revit Architecture - General
    Last Post: 2009-10-13, 01:44 AM
  2. Do You Know Undo ?
    By pferreira in forum AutoCAD Tips & Tricks
    Last Post: 2007-03-15, 01:28 PM
  3. Undo does it all without asking
    By sandy.sebastian in forum AutoCAD General
    Last Post: 2005-09-27, 05:53 AM
  4. Undo limiting to one undo
    By mjsregister in forum AutoCAD General
    Last Post: 2005-02-01, 06:57 PM
