Thread: Information Transfer between TRACE 700 and AutoDesk Revit MEP 2012
    Default Information Transfer between TRACE 700 and AutoDesk Revit MEP 2012
    Hi,
    I was just wondering if someone could provide me with an overview of information transfer between TRACE 700 and AutoDesk Revit MEP 2012 in terms of:
    - The type of information
    - The file format of the information
    - The direction of the transfer
    2007-09
    490
    Default Re: Information Transfer between TRACE 700 and AutoDesk Revit MEP 2012
    Look up Class MP4973 on the AU website. I sat in on this class and it is the closest thing to what you are looking for...also google the RGT document by Shariq Ali...a little dated but still a great resource.
    2007-06
    Des Moines, IA
    224
    Revit transfers wall, roof and wall/roof opening geometry and associated room numbers to TRACE. TRACE can transfer individual room load data back into Revit IF the room numbers have not changed. Both transfers use the GBXML file format. You can also update the geometry from Revit to TRACE if the room name or numbers have not changed. Any change in the room names will create a new room in TRACE or not allow you to transfer information back into Revit from TRACE.
  1. 2012: Information Transfer between CostX and AutoDesk Revit MEP 2012
    By j.vancuylenberg183226 in forum Revit MEP - General
    Last Post: 2013-04-12, 12:39 AM
  2. 2012: tracé en différé, dwg in pdf ???
    By da_fi in forum AutoCAD General
    Last Post: 2012-10-31, 12:49 PM
  3. 2012: Information transfer between Bentley Tas Simulator V8i and AutoDesk Revit MEP 2012
    Last Post: 2012-04-27, 12:46 AM
  4. 2012: Information transfer between Google SketchUp Pro and AutoDesk Revit MEP 2012
    Last Post: 2012-04-26, 11:29 PM
