Folks,
3-6 times a day for the last few weeks Revit will seemingly randomly get stuck for 5-10 minutes at a time. Sometimes it'll be after printing to PDF, other times it'll be after just changing views or reloading families.
My computer is well above minimum specs. I'm running Revit 2012. This problem has been apparent when working in old revit files or brand new ones or when the file is saved locally or on the network.
Any ideas what could be causing this or what tests I could run to isolate the problem? While the program is Not Responding, the CUP usage is at 0% and the RAM is still high (right now it's stuck at 907MB).
I have contacted Autodesk with this apparent glitch, but haven't heard back yet so thought I'd take it up with you.
