Thread: Complex Block Color
    2009-10
    7
    Default Complex Block Color
    Hello,
    I'm currently drawing a detail and I want the environment to be shown on this detail. The environment is already a bloc but it is composed of a lot of blocs. I would like the environment to be in pale color in my detail but the complexity of the environment don't give me the option to put my lines "byblock" so i could put my block in pale color. I could explose it, but if there is an other way to proceed it would be really usefull because the exploded block won't be updated if I change some informations in my environment.
    I'm not sure that i'm really clear so if you have any questions about my problem ask me.
    2001-12
    St. Louis
    5,406
    Default Re: Complex Block Color
    Quote Originally Posted by alien_srp View Post
    Hello,
    Which software package are you using?
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2009-10
    7
    Hello,
    I'm using AutoCAD Lt 2012
    Sorry for the delay..
    2001-12
    St. Louis
    5,406
    No problem.
    I'm going to go ahead and move this over to the LT forum.
    Thanks.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    in the upper right corner
    3,504
    Hello,
    Can you redefine all the blocks to be ByLayer and then just change the layer colors/line weights?
    That's what I would do.
    Cairo - no, not Illinois
    5,069
    Xref in the environment, rather than use a block insertion. that way it will be easy(er) to update when changes happen, and it will be easier to control the display.
  1. 2014: Complex Dynamic Block Issues
    By mbrandt5 in forum Dynamic Blocks - Technical
    Last Post: 2015-04-27, 10:55 PM
  2. 2014: Complex Dynamic Block problem
    By gambibolduc2563069 in forum Dynamic Blocks - Technical
    Last Post: 2014-02-25, 09:54 PM
  3. Complex Block Swap?
    By m4rk.wr1ght105915 in forum AutoLISP
    Last Post: 2012-08-15, 05:02 PM
  4. Complex Block (I think)
    By mike.mccall in forum Dynamic Blocks - Technical
    Last Post: 2010-07-27, 07:11 PM
  5. Complex solution for Dynamic Block
    By Aarer in forum AutoCAD General
    Last Post: 2008-09-23, 09:23 PM
