Thread: Viewport scale
    2012-03
    4
    Default Viewport scale
    I have been tasked with creating a command for my team to create frame references for ships. I almost had the routine done but then they asked me to have it scale based on the scale of the view port. As it sits right now they have top key in the scale (***) I would much rather them just pick the vport they would like. My issue is I can not seem to get a useable number.
    So my question is
    How do I get the view port scale?
    Acad help showed me this "NoteThe ZOOM XP factor is calculated with the following formula: group_41 / group_45 (or pspace_height / mspace_height)."
    but I always get nil returned when I try to grab the val with something like this
    (defun c:test()
    (setq VP (ssget(list (cons 0 "viewport"))))
    (setq vps (getval 41 VP))
    Moderator BlackBox's Avatar
    2,383
    Default Re: Viewport scale
    Unfortunately, Viewports are not entirely accessible via DXF... Visual LISP (read VLA-Object) is required. Specifically, look into the AcDbViewport Object's CustomScale, and/or StandardScale Properties.
    For example:
    (defun c:DVP () (c:DumpViewport))
    (defun c:DumpViewport (/ ss)
      (vl-load-com)
      (if (setq ss (ssget ":S:E:L" '((0 . "VIEWPORT"))))
        (progn
          (textpage)
          (vlax-dump-object (vlax-ename->vla-object (ssname ss 0)) T))
        (prompt "\n** Nothing selected ** "))
      (princ))
    **Edit - ... And, welcome to AUGI! BTW
    "Potential has a shelf life." - Margaret Atwood
    2012-03
    4
    Thanks and thanks. That is helpful info. Have been working with it for a couple years now but am still by far a noob.
    2,383
    No worries; we all start somewhere.
  1. match annotation scale to viewport scale
    By ccowgill in forum AutoLISP
    Last Post: 2009-05-04, 10:54 PM
  2. match annotation scale to viewport scale
    By Mary_Ellen_Banning in forum AutoCAD General
    Last Post: 2008-12-05, 07:20 AM
  3. Viewport scale changes after using Maximise Viewport facility
    By larry.111254 in forum AutoCAD LT - General
    Last Post: 2007-02-21, 11:08 AM
  4. Replies: 0
    Last Post: 2006-11-28, 09:37 PM
