Thread: Frame around saved view in model space
    2007-11
    2
    Default Frame around saved view in model space
    How do i turn on a frame or box showing the boundary of a saved view in model space?
    2002-12
    49
    Default Re: Frame around saved view in model space
    I wasn't aware this could be done. What I do to define the saved view region is turn on the GRID and have the spacing set to 20'. Next, draw a RECTANGLE defining the extents of the view. Set the LIMITS from the lower left and to the upper right corners of the rectangle. The grid's "dots" should now fill the region of the rectangle. Now erase the rectangle. What's left is a an visual area representation of where the team should design within. This is setup in all of my template and Project Navigator VIEW template files. I also set the SNAP spacing to 10', although it is set to be off.
  1. Problem with linked model view showing as wire frame
    By mattw in forum Revit MEP - General
    Last Post: 2010-03-23, 08:07 PM
  2. Rotating a Model Space View
    By dustin.fike in forum ACA General
    Last Post: 2009-05-01, 03:44 PM
  3. New Model Space View- VIEWS
    By rchitectonics in forum ACA General
    Last Post: 2007-02-14, 04:51 PM
  4. Add Model Space View
    By fletch97 in forum ACA General
    Last Post: 2006-06-07, 07:40 PM
