Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Revit MEP 2013
    2007-06
    Des Moines, IA
    222
    Default Revit MEP 2013
    Revit 2013 Versions are starting to show up on Autodesk Subscription and that led me on a search for the new features. I've never been too excited about the changes they've made to Revit MEP but this new version sounds like it might address many of the broken features, or at least the ones I noticed are broken. Here is where I went to see a summary of the "What's New"
    http://bimboom.blogspot.com/2012/03/...e-summary.html
    First, it looks like the duct fitting database will finally be fixed. Whether that turns out to be true remains to be seen. This would be huge if it was an accurate method of calculating pressure drops like it was supposed to be all along.
    Second, you can export building thermal resistance data. Again, remains to be seen how accurate/useful this will be. Will it calculate it from the architects walls or are we stuck re-inputting wall data?
    Exportable pressure drop data, which kinda ties into the duct fitting database. Will be nice to export something that you can then modify. They also split pressure drop data before/after taps now. Before it would not.
    Loop leaders - weee! We actually had a custom made loop symbol that we placed and drew a leader line and text to.
    2012-03
    Default Re: Revit MEP 2013
    Yes, I can't wait to see if the static pressure calcs actually work.
    2007-04
    I come from a land downunder...
    225
    Revit MEP 2013!! WOW!....I can barely contain my excitement!
    I'm not young enough to know everything.
    2007-06
    Des Moines, IA
    222
    Just installed 2013...still can't calculate pressure drop through a tap. The duct pressure report is kinda cool though, just useless.
    AUGI Addict mattw's Avatar
    2002-06
    North Central CT
    1,007
    Quote Originally Posted by tys90 View Post
    Do you have a link for the download? The only download I've seen is for the 30-day trial. I thought previous releases had a different link to download???
    Matt
    2002-06
    North Central CT
    1,007
    Quote Originally Posted by mattw View Post
    Matt
    Nevermind... just as I clicked the "post" button I realized I hadn't checked the subscription site... just the regular Autodesk site. I found it on the subscription site.
    Revit MEP Moderator mjdanowski's Avatar
    2007-03
    889
    Is it wrong that the feature I am most excited about is the loop leader?
    2008-02
    Austin, TX
    175
    Quote Originally Posted by mjdanowski View Post
    Not gonna lie, that's my favorite little feature on the list.
    Now about that text editor that was number 1 on the Wishlist for all 3 Revit platforms....
    2007-06
    Des Moines, IA
    222
    Interesting response from the support ticket I opened after I found out the taps still didn't work:
    Thank you for your patience while we researched this issue.
    At this time, we are still working on getting Revit to pull the correct ASHRAE Table. The permanent fix will most likely require that the code for Revit to be changed and as such, the workaround for now is to set the family to specific loss and specify the loss.
    As our Development group had confirmed the issue and they are actively working to fix the issue., there is not anything more for Product Support to do on this case and the case will be closed at this time. Please note that this does not impact the priority or timeline for the implementation of the fix by our Development group, it only means I will not be actively involved.
    The above "fix" was what you had to do since the duct pressure calcs were introduced in 2009. 5 releases with broken code in it is pathetic.
    2002-09
    Madison, WI
    4,440
    I see RS isn't the only version to have the support team dismiss things that have been know problems since release 2.
    Dave Peterson
    Acad 2012 - Revit Structure 2013 - Z220 - Win 7 64 - i7-3770 3.4GHz 32GB Ram
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
  1. Revit 2013 here's whats new
    By gordons.68934 in forum Revit Architecture - General
    Last Post: 2012-06-05, 02:31 PM
  2. Revit 2013 - novidades
    By decio.ferreira in forum Português - Revit
    Last Post: 2012-04-09, 12:17 AM
  3. AutoCAd 2013 - Novidades
    By decio.ferreira in forum Português - AutoCAD / AutoCAD LT
    Last Post: 2012-03-28, 02:54 PM
  4. (2013) AutoCAD Core
    By cadtag in forum AutoCAD Customization
    Last Post: 2012-03-01, 06:57 PM
