Results 1 to 10 of 12
Thread: Revit vs. Auto Cad for residential house plans
    Default Revit vs. Auto Cad for residential house plans
    I am a student studying construction management. This summer I want to draw residential house plans on the side. I have had quite a bit of experience in Revit and feel the most comfortable using it but the draftsman at the company I work for swears auto cad is the only way to go. Should I invest time in learning auto cad. Can Revit keep up with ...pass auto cad when it comes to drawing residential elevations, roofs, and plans?
    Thanks
    2003-04
    Irvine, CA
    6,770
    Default Re: Revit vs. Auto Cad for residential house plans
    Do the work in Revit. If someone needs dwg files then export from Revit. You already know Revit. Nothing wrong with knowing more software but there is no point being inefficient if it's your sidework.
    I could stop if I wanted to charliep's Avatar
    2003-02
    Northumberland, U.K.
    335
    My regular work is allmost exclusively re modelling and I use Revit. Much quicker and more accurate in my opinion.
    Regards
    Charlie Priest
    Enterprise Architectural Services Ltd.
    2006-08
    7
    My company does a lot of work for national housebuilders in the UK and we use Revit for the production of all the drawings. We now only use Autocad for legasy work.
    You can produce a lot more information in a shorter space of time so stick with Revit.
    Thanks for the comments. I found them very valuable. I enjoy using Revit. I am glad to hear that guys are using Revit in a residential setting. Most of what we talk about in class is BIM and clash detection...not as useful in residential. Are you guys using Revit for your Take offs as well?
    Thanks
    AUGI Addict jsteinhauer's Avatar
    2007-09
    Madison, WI
    1,029
    Quote Originally Posted by raymondjdawson925863 View Post
    Thanks
    Hi Ray,
    I suggest you race this draftsman on a set of plans. Generate your exterior elevation, interior elevations & sections. Generate schedules for the windows & doors, room schedules, as well as material take offs. Then change the window & door sizes, and see if he can catch up. Even if you're not that proficient in Revit, you should be able to blow him out of the water. Only issue you may have is family content.
    Also ask him to generate a 3D model for renderings. Attached are some files from a residential project I did with 1-2 years of experience in Revit. This house went together very well, and using Revit helped the client understand the shape and feel of the house, prior to it being built, with the use of renderings, live sections & walk-through.
    Hope this helps,
    Jeff S.
    'When I am working on a problem, I never think about beauty but when I have finished, if the solution is not beautiful, I know it is wrong.' - R. Buckminster Fuller
    I could stop if I wanted to Revitaoist's Avatar
    2009-11
    276
    I'll also say Revit is much better than CAD, and this is an age old debate. Anyone saying CAD is better than Revit has a bad case of sour grapes. But, you should take the time to learn CAD. It is a very powerful program, and having a diversity of skills is worth the time invested.
    2009-03
    Somerville, MA
    669
    I definitely have to agree with Revitaoist about learning Autocad. At least for quite a few years to come, it is still the most-used drafting program in the construction industry. I imagine your goal upon graduating will be to get a job, so learning the most common software would be wise.
    That said, I think the drafter at the company is speaking from an uninformed and inexperienced (with Revit, anyway) point of view.
    AUGI Addict MikeJarosz's Avatar
    2003-09
    New York NY
    1,005
    Learning a full featured CAD system is a major undertaking, and some people, after mastering their first software package, also expect it to be their last. In my opinion, that is an unrealistic expectation.
    I began my career years ago with pencil and yellow trace. Today, I expect to be downloading Revit 2013. I have learned four completely different CAD systems, not counting versions. I have worked in every version of Revit since version 6. At that time, the Acad skeptics were laughing at us. Until we unveiled the World Trade Center in Revit, that is.
    Just as Acad swept away the competition in its heyday, I believe Revit is poised to overtake the entire building industry, not just architectural design. Look up some architecture job ads. A few years back, they required Acad, Revit desirable. Today they require Revit, Acad desirable.
    Anyone planning to continue only in Acad had better be planning their retirement too.
    "everything you know is wrong...." -FST
    I could stop if I wanted to zanzibarbob7's Avatar
    2004-08
    Wayne, ME
    443
    This issue is a "No Brainer." Use Revit. If you look at it from a efficiency standpoint ask, "How far can you leverage your work?" Revit is the winner. Also ask, "If I only have time to learn one program which should it be?" Again, Revit is the winner. Learn Revit first and if you have time learn AutoCAD. It's like learning English first then learning French, German and Swahili, later. People who push Swahili as a first language usually only know Swahili and are just too narrow minded to learn anything new. Revit!!!
    Thomas W. Hillis, LEED AP
  1. night render residential house
    By npv_89 in forum Revit - Gallery
    Last Post: 2007-10-17, 12:04 AM
  2. Auto Cad floor plans to Revit
    By gallienhanson in forum Revit Architecture - General
    Last Post: 2005-01-12, 05:43 PM
