Thread: object fields in xref
    2003-11
    285
    Default object fields in xref
    Surprisingly, there is only one post about this and it's unanswered.
    I have 2 blocks with field attributes that report the x and y position of a non-plotting point in the block. It works fine in its original file but when it is xreffed into another drawing the field values are incorrect. I've had this issue with the length parameter of a block as well.
    I would love to use fields for this type of application more but right now i'm going to have to explode all the blocks to get the appropriate values to display.
    (see screenshots)
    Anybody help?
    2008-03
    383
    Default Re: object fields in xref
    Looks like a problem on the Unit type on another drawing, can you attach both the xref and the drawing you where attaching to.
  1. 2014: Added object data fields to Polyline, but object data is empty or zero
    By tntdraftsol in forum AutoCAD Map 3D - General
    Last Post: 2015-07-24, 12:20 PM
  2. Scaled DB and object fields...
    By randyspear in forum Dynamic Blocks - Technical
    Last Post: 2009-09-15, 02:18 PM
  3. Get Data From Xref'ed Fields
    By Richard McDonald in forum AutoCAD Fields
    Last Post: 2007-09-20, 01:08 PM
  4. Volumn of 3D object in fields
    Last Post: 2006-09-26, 01:45 PM
  5. Fields update if associated with different object.
    Last Post: 2006-03-19, 11:32 PM
