Thread: Revit Rendering (geometry edges)
    2010-01
    39
    Question Revit Rendering (geometry edges)
    How do you go about dealing with geometry edges when rendering an interior scene?
    For instance, you build a casework model, but all the edges are normally sharp 90 degrees (unless you fillet them),
    which does not usually generate a realistic result, as there's no such thing like perfect 90 degree corner edges in real life.
    In Mental Ray, I believe there is a command called "Rounding Corners", or in VRay, there is a similar command such as "VRayEdges Tex",
    to simulate real world conditions for geometry edges.
    I was wondering how you normally deal with it in Revit.
    Thanks in advance
    262
    Default Re: Revit Rendering (geometry edges)
    very interesting question. But the question is what are you trying to render and, if you are that close to tell, maybe you can FBX the scene to 3dsmax. As far as I know, where isn't a magical material in Revit for that.
  1. Modifying Geometry in ROBOT and Updating Geometry in REVIT
    By stephen.lewis in forum Robot Structural Analysis
    Last Post: 2009-12-09, 04:32 AM
  2. Curved edges shown as straignt edges
    By MARK.PATERSON in forum AMEP Wish List
    Last Post: 2009-03-26, 06:51 PM
  3. Edges not rendering properly in 3D visual styles
    By andrew.189591 in forum AutoCAD General
    Last Post: 2009-02-10, 05:50 PM
  4. Rendering thick glass edges
    By dbaldacchino in forum Revit - Rendering
    Last Post: 2008-09-26, 06:17 PM
  5. Jagged edges instead of nice smooth edges on Rendered model
    By strangedj in forum AutoCAD 3D (2006 or below)
    Last Post: 2005-04-25, 11:50 AM
