Results 1 to 8 of 8
Thread: AutoCAD 2012 - 64bit Windows 7 Memory Issue
    2015-09
    420
    Default AutoCAD 2012 - 64bit Windows 7 Memory Issue
    Hello AUGI Members,
    Our company deployed AutoCAD 2012 on Windows 7 workstations in a 64bit environment with 8gigs of memory. We have noticed the performance was not great to begin with and there seems to be a memory leak because after working a while with multiple drawings the system slows down dramatically and eventually AutoCAD crashes. Is this a know issue with AutoCAD 2012....?? Is there a fix for this....??
    The overall performance is so poor that we are thinking to installing AutoCAD 2013 to see if there is any improvement.....!
    Has anyone experienced similar results....?? Is there a better solution....?? Can anyone please provide some help....??
    Best Regards,
    Vince
    2001-12
    St. Louis
    5,408
    Default Re: AutoCAD 2012 - 64bit Windows 7 Memory Issue
    Quote Originally Posted by vferrara View Post
    Hello AUGI Members,
    Best Regards,
    Vince
    Hmm, not that it's any help, but, I have been running AutoCAD 2012 on a win7 (64) machine for well over a year and have not had any trouble with it crashing, even when having multiple large drawings open at once...
    Is there anything special about the drawing contents? (I did hear about a documented memory leak with Revit 2012, but, it was definitely associated with the use of pointclouds)
    Melanie Stone
    @MistresDorkness
    Technical Editor
    5,719
    FWIW - We too work in Windows 7 64-Bit, using Land Desktop 2009, Civil 3D 2011, Civil 3D 2012, and MEP 2012... but we've installed 16 GB RAM, and 2 GB (min) Video Cards. We are not experiencing the behavior you mention here.
    2015-09
    420
    Hi Melanie,
    Thank you for your response....!
    We are a structural engineering firm and there should be nothing unusual about our drawings. They vary in size but the average file is approximately 2-3 MB's. Our engineers like to open 3-5 drawings at the same time (some of them from architectural consultants) and go back and forth between the open drawing files......this is where we see the biggest memory loss. I also have batch routines the can process many drawings and when the routine starts the performance is very good however, as it opens and closes the drawing files you can see a noticable slowdown (after 15 - 20 drawings) in the time it takes to open each drawing file and do its thing.
    We do have a few workstations with 16 gigs of memory and the performance on these machines is better but we can still see the performance slowdown as drawing files are opened and then closed. The only thing I failed to mention before is that we are using AutoCAD Architecture 2012 not vanilla AutoCAD......but I do not think that should make a difference.
    Everyone in the company is complaining about the poor performance on the Windows 7 64 bit workstations compared to the old Windows XP 32 bit workstations they were using before.
    We need to do something but I am not sure what.....??
    Best Regards,
    Vince
    0,0,0 The Origin
    8,570
    It may be a Win_7 problem rather than an acad one.
    Check that Windows can actually use all the available RAM; messages like "8 Gb RAM (3.8 Gb available)" are not unusual.
    See my thread "A little story" in this forum.
    Cairo - no, not Illinois
    5,069
    Quote Originally Posted by RenderMan View Post
    or 256 Mb ram video card -- that's all IT claims we need to have. pos optiplex crud $%^&ragn snargl freglin !@$
    However, back to the OP:
    Personal experience suggests that Adesk has numerous memory leaks, and does not do a great job of freeimg memory up when it's no longer really used. Generally I find it expedient to either kill Acad periodically, reboot over lunch, or wait for it to hang and then crash.
    Probably a good idea to kill commcenter -- see http://otb.manusoft.com/2012/03/turn...tocad-2013.htm for a how-to.
    5,719
    Your group is larger, and shafted you guys when equipment purchases took place after acquisition... When's the last time you checked the Desktop/Notebook Computer Quotation form(s) on the Intra-web?
    Currently the US Desktop ('CAD System') is 1GB VC standard, and the US Notebooks (15.6, and 17-inch 'Performance Laptops') come with 2GB Mobile VC's... each of which are able to upgraded at the time of purchase.
    /offtopic
    2010-10
    South Dakota
    37
    I've noticed/experienced similar issues and found that as long as I restart over lunch things go well. The other day it was absurdly slow and I noticed a gigantic memory hog (acad.exe); Windows 7, 64 bit.
  1. Windows 8 - Has anybody run AutoCAD on Windows 8 64bit?
    By Curt340924 in forum Operating Systems
    Last Post: 2014-04-11, 03:59 PM
  2. Windows 7 - Windows 7 Autocad 2012 Plotting Issue
    By richelleharp in forum Operating Systems
    Last Post: 2012-08-07, 09:28 PM
  3. Autocad 2012 and Windows 7 64bit
    By tcrain1981 in forum Hardware
    Last Post: 2012-07-30, 04:52 PM
  4. plotting issue w/64bit 2012
    By sjsl in forum Revit - Plotting/Printing/Exporting
    Last Post: 2011-11-03, 07:51 PM
  5. Here is a show-stopper for us. Windows 7 Revit 2009 64bit issue
    By Baldwin_4-6-0 in forum Revit Architecture - General
    Last Post: 2010-06-03, 12:36 PM
