Thread: Title Block Insertion issues
    2007-01
    5
    Default Title Block Insertion issues
    Hi! My co-worker is trying to insert a 30x42 title block as an external reference into paper space. I am stumped. The sheet set up is correct, and the file she is inserting into looks scaled correctly, but when the Xref is inserted, it's very small, maybe 5x7 in paper space. Can you help me get this solved? I am sure it is kust a setting...Thank you!
    Certifiable AUGI Addict Wanderer's Avatar
    2001-12
    St. Louis
    4,285
    Default Re: Title Block Insertion issues
    Check the UNITS, especially INSUNITS, as there is definitely some scaling going on.
    Melanie Perry @MistresDorkness
    Facilities CAD Management (FM - MEP/FP)
    Technical Editor
    Revit MEP 2013 Suite
    not all who wander are lost
  1. Revit 2009 MEP title block revision issues.
    By Blakester122 in forum Revit MEP - General
    Last Post: 2009-08-21, 01:13 PM
  2. Replies: 1
    Last Post: 2007-01-07, 09:08 AM
  3. Loose dynamic states from sub block after insertion into master block
    By ANRCREATIONS in forum Dynamic Blocks - Technical
    Last Post: 2005-11-15, 01:41 PM
  4. Convert MDT Title Block to Inventor 10 Title Block
    By julesgordon in forum Inventor - General
    Last Post: 2005-07-18, 08:34 PM
