Thread: Revit Beams & Analytical Beams
    Active Member Bobby C. Jones's Avatar
    2001-08
    Texas
    62
    Default Revit Beams & Analytical Beams
    If I draw a beam in one view it comes in as a structural framing member, just as desired. If I duplicate that view all beams come in as analytical beams, not at all as desired. What key piece of info am I missing? Thanks.
    Certifiable AUGI Addict
    2004-05
    St. Louis, Missouri
    3,135
    Default Re: Revit Beams & Analytical Beams
    1. Did you use Duplicate with Detailing or just Duplicate?
    2. Is there a View Template applied to either the original or duplicated views?
    3. Try turning off Analytical properties in the view.
    2001-08
    Texas
    62
    Quote Originally Posted by cliff collins View Post
    1. Duplicate with detailing.
    2. I created a view template from the original view and applied it to the new view.
    3. I had to turn on the analytical beams in order to see that I was actually drawing something; they are off by default.
    Thanks Cliff
  1. Copy Monitor Beams &/or attach beams to linked model
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2018-11-24, 12:23 AM
  2. How to place beams over beams
    By sythlord632673 in forum Revit Structure - General
    Last Post: 2011-04-01, 07:19 AM
  3. Curved beams with beams attached?
    By stephan.villeneuve in forum Revit Structure - General
    Last Post: 2010-01-25, 03:15 PM
  4. I would like the structural beams, etc. to have an option for drawing curved beams.
    Last Post: 2008-07-04, 04:56 AM
  5. Built-up Beams (constructing & analytical)
    By dlevesque in forum Revit Structure - General
    Last Post: 2007-09-16, 05:10 PM
