Thread: Annotation Symbols vs Scale
    2012-03
    26
    Default Annotation Symbols vs Scale
    I have an outlet receptacle and a data receptacle that are side by side. The annotation symbols that represent each outlet are centred on the Center (left/Right) reference plane. When the scales change, the annotation symbols change accordingly. (which is perfect)
    My problem is, when the scale does change, the annotation symbols become graphically incorrect in the sense that they become to far apart (at small scale) and to close together (at large scale).
    I need some solution that will maintain the distance between my annotation symbols, regardless of scale.
    Any Ideas??
    Thank you much in advance!!
    2002-09
    Madison, WI
    5,495
    Default Re: Annotation Symbols vs Scale
    I think they only way you can get that to work would be to have them as one family so when the scale changes, the distance between the symbols would change. But I could be wrong.
    Dave Peterson
    BIM Coordinator
    Acad - 2016 - Revit 2018 w/ A360 - Navisworks - 3ds 2018 - Ensacpe - Lumion - Win 7 64 - i7-6700K 4.0GHz 32GB DDR4 Ram - Nvidia Quadro K2200
    "The more you know, the less you know, because the more you know you don't know". --M. Lin
  1. 2016: Revit Annotation Scale of Schematic Symbols
    By jparkhurst in forum Revit MEP - Families
    Last Post: 2015-05-07, 08:52 PM
  2. Replies: 0
    Last Post: 2011-12-15, 02:02 PM
  3. Replies: 9
    Last Post: 2010-11-25, 11:03 AM
  4. Imported CAD symbols VS Annotation 2D symbols
    By Binu Mathew in forum Revit MEP - General
    Last Post: 2009-12-30, 03:36 PM
  5. Replies: 0
    Last Post: 2009-02-01, 06:04 PM
