Thread: Stop annotative activity across xrefs?
    2008-05
    414
    Default Stop annotative activity across xrefs?
    We have a cool new feature that I need to turn off. I'm having deja-vu.
    So now AutoCAD will automatically go and start changing the annotative properties of objects, text and dimension styles when you change the annotative scale of the viewport.
    This is causing me a lot of problems. I turned off annoauto...something or other, and now inserted objects come in incorrectly until I specifically update the annotative scale of each.
    I'd like inserted objects to come in automatically scaled, but I really need to stop AutoCAD from going across xrefs when I change a viewport's annotative scale.
    2007-07
    Jo'burg SA
    4,344
    Default Re: Stop annotative activity across xrefs?
    Unfortunately that's an either or scenario, so it only works if turned on, but then works for everything. The variable you're trying to remember is AnnoAutoScale, there's a toggle switch in the status bar next to the Anno Scales drop-down and the "AnnoAllVisible" toggle.
    Alternatively, paste the objects, then select them and right-click: Annotative Object Scale >> Add Current Scale.
  1. Annotative XREFs
    By philA in forum AutoCAD Annotation
    Last Post: 2009-09-29, 01:16 PM
  2. Activity...
    By sleimgruber06 in forum Revit - Student Support
    Last Post: 2006-09-25, 08:41 PM
