Thread: defaulting underlay to none during view setup
    2010-06
    62
    Default defaulting underlay to none during view setup
    question,
    I am wnating to know if there is a way to have the undelay set to none when you use the add-in viewstetup. right now the template has them set to noe but when I create my views using this add-in they change to the level below. Is there a setting that i am missing?
    I could stop if I wanted to mhartmann's Avatar
    2015-11
    Saint Louis, MO
    465
    Default Re: defaulting underlay to none during view setup
    i don't think there is, i've complained about that as well...
    2011-08
    3
    It seems like there is no way to fix that behavior however here is the post where you can find a python script that will batch-change Underlay setting to None for any selected views
    Member gadamson's Avatar
    2002-06
    4
    I know it has been over 2 years. When I select the views to use the Python script, they dont show up in the filter. still says 0. It seems that the script needs to recognized the selected views as a selection and then iterate through each one. Problem is, I cant get Revit to recognize that I selected the views.
  1. 2015: Help with view depth and underlay
    By bsmith685274 in forum Revit MEP - General
    Last Post: 2015-02-26, 03:27 PM
  2. 2012: New plan view, no underlay please!
    By damon.sidel in forum Revit Architecture - General
    Last Post: 2013-05-13, 12:46 AM
  3. 2013: Is there a way to control underlay view?
    By Bluefairy in forum Revit Architecture - General
    Last Post: 2013-04-01, 12:35 AM
  4. View Properties - Underlay
    By agustnj.187972 in forum Revit Architecture - General
    Last Post: 2009-08-25, 11:14 AM
  5. 8.0/E Underlay view
    By dpasa in forum Revit Architecture - Wish List
    Last Post: 2006-05-05, 05:40 PM
