Results 1 to 9 of 9
Thread: 1 door 2 walls
    2012-04
    15
    Default 1 door 2 walls
    Hey,
    How do i solve this? I have a concrete wall (existing) and i put a dry wall in front of it (New construction). I want to place a door but the wood casement is placed like the picture below.
    Thanks in advance.
    2015-11
    Madison, WI
    1,318
    Default Re: 1 door 2 walls
    Try to 'Join' the walls together. If they are within an inch or two they should link together. This means that you won't have to place an opening in, or modify the profile of the gypsum wall.
    Cheers,
    Jeff S.
    AUGI Addict cdatechguy's Avatar
    2006-10
    CdA, ID
    1,533
    The door frame wrap will still wrap only the wall that its hosted to...
    You would need to create a custom door that would allow for extra wall thickness...
    Michael "MP" Patrick
    "I only drink :coffee: until it's acceptable to drink :beer: or :whiskey: or :wine:"
    2012-04
    15
    I knew the 'join' command and it doesn't work.
    are you having tips cdatechguy? i'm not familiar with family's(not yet )
    grtz.
    Werner
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,440
    You will need to add a ref. plane in your door family that you have a dimension to called "interior furring width" or something like that, then base you frame and trim on that. Make it instance based if you have multiple wall thickinesses.
    Scott D. Brown, AIA
    BECK
    2012-04
    15
    Thank already,
    But is it possible to explain me something more. I'm a beginner.
    I have adapt the family that when i change the dimensions, but it happens not automatic (other thickness) and when i flip the door it does not work.
    Perhaps there is a good tutorial to learn how 'family's works.
    2006-10
    CdA, ID
    1,533
    Personally, I think your going the wrong direction with the door type, as usually wraps apply with interior wood/steel studs... I could be wrong though, but all the exterior conditions that I have uses a butted frame... (see pic....ignore the fact its offset a little too much...need to fix that)
    But if you really want it to wrap, instead of using the wall reference planes for your frame, you essentially add another reference plane (what Scott said) to one side (or both) to allow for an exterior and interior finish. Base your frame width to those reference planes instead of to the wall.
    2012-04
    15
    Thanks for the answers.
    I am going to start with this advice. And first learn to walk before i can run.
    I downloaded a family guide so i can understand the basic first.
    Grtz.
    Werner
    2006-09
    259
    Have a look at the OOTB door family with external/internal reference planes added (as Scott explained) to control frame depth, for your quick reference.
    R
  1. Replies: 0
    Last Post: 2013-04-17, 04:46 AM
  2. Door with no walls
    By belinda.66428 in forum Revit Architecture - Families
    Last Post: 2006-11-08, 12:54 AM
  3. door in two walls overlap
    By o_dragos in forum ACA General
    Last Post: 2006-07-18, 11:26 PM
  4. 3 Walls, 1 Door
    By Matt Brennan in forum Revit Architecture - Tips & Tricks
    Last Post: 2005-09-04, 07:17 AM
  5. Door not cutting through walls
    By Griff in forum Revit Architecture - General
    Last Post: 2004-02-03, 10:43 PM
