Thread: split a wall
    100 Club chrisr's Avatar
    2005-01
    Ballina,Ireland
    142
    Lightbulb split a wall
    I have an external wall in my Revit model which part of it is to be existing, part to be a new wall. Same make up, size, height extra. How every I wish now to split this wall in two. As when I am place rebars along it. I don't want them placed in the existing section. I do not want to redraw the wall and have a join, as there are numerous components/ doors extra attached to this wall.
    Any ideas on how to cut the wall into two separate walls.
    Certifiable AUGI Addict
    2004-05
    St. Louis, Missouri
    3,135
    Default Re: split a wall
    Create two walls, 1 in the Existing Phase and 1 in New Construction Phase.
    2002-09
    Madison, WI
    5,688
    If you have the wall modeled already, I'd use the split tool to create 2 walls, place one on the existing phase and the other on the new construction phase.
  1. Split wall does not inherit original wall properties
    Last Post: 2013-02-19, 03:09 PM
  2. split wall
    By CADMama in forum Revit Architecture - General
    Last Post: 2010-03-24, 07:13 PM
  3. Wall Split Horizontal
    By crugg in forum Revit Architecture - General
    Last Post: 2009-10-02, 11:26 PM
  4. Can you join a wall that has been “Split wall with Gap”
    By JH75 in forum Revit Structure - General
    Last Post: 2009-05-27, 05:02 AM
  5. tilt wall panels, split wall?
    By rrothwel in forum Revit Architecture - General
    Last Post: 2008-10-23, 11:03 PM
