Results 1 to 8 of 8
Thread: Change titleblock attribute value throughout DWG
    2004-10
    Scotland
    102
    Default Change titleblock attribute value throughout DWG
    AutoCAD LT 2008
    Hi, I've had a look through the forum, but I can't find an answer which doesn't involve using LISP.
    Is there a way for me to create a macro which can change the value of an attribute (for the project stage) in a title block throughout a number of layouts in a drawing?
    I can use the -ATTEDIT command to change one known value to another, but it doesn't change more than the current layout I'm in (or the last layout I was in, if I run the command from Model Space).
    I would have thought that this problem would have been raised before; is a command available, but I haven't found it yet?
    Thanks for any help anyone can provide,
    Regards,
    JGA
    2001-12
    Dallas, TX
    229
    Default Re: Change titleblock attribute value throughout DWG
    That level of programming is considered by Autodesk to be available only in AutoCAD, not LT.
    Explore the CTAB variable in LT and see if it can do what you want with layouts. And there are 3rd party (purchased) script processors that claim to support LT, that may be what you also need if you want to run a script on many DWG files.
    Have you considered a 'better' approach, since your issue is limited to a titleblock edit: XREF your titleblock into all of your layouts, then when you need to edit constant item in it you just open that DWG file and do so. Then reload the Xref once in each file.
    2004-10
    Scotland
    102
    Quote Originally Posted by dean.23438 View Post
    ...Have you considered a 'better' approach, since your issue is limited to a titleblock edit: XREF your titleblock into all of your layouts, then when you need to edit constant item in it you just open that DWG file and do so. Then reload the Xref once in each file.
    Dean,
    Thanks for replying. I was hoping that the experts may have found a work around!
    I think the Xref route will be the most straight forward.
    Regards,
    JGA
    5,719
    Does LT not have access to Sheet Set Manager (SSM)?
    We use SSM, setup with custom properties, which update our ttitle block(s) use fields within the title block attributes. New client name, or phase of work... change the SSM property and publish all 500+ drawings; done.
    2008-10
    You could try the FIND command. and replace. Be careful of unintended consequences. You could lock all layers except the layers the attribute is on to limit consequences. just one low-tech short-term solution but I agree with xreffed titleblock. Thats how I usually handle the situation I think you are talking about. Good luck.
    2004-10
    Scotland
    102
    RenderMan & jeffcsch71, thanks to you both for posting.
    Unfortunately, AutoCAD LT doesn't have access to the SSM.
    jeffcsch71, I did give the FIND command a trial; while it works, I found it a bit clunky when the drawing is full of the same letter or numeral as the revision I'm trying to change!
    Regards,
    JGA
    2012-04
    Hi JGA,
    Have you found solution for your above query?? I too have one such task. Pls help
    2004-10
    Scotland
    102
    mahe304475,
    Not exactly. Using the FIND command was the nearest I came to a solution with existing drawings. The Sheet Set Manager is also now available from AutoCAD LT, but I found it troublesome with lost links in older full versions of ACAD. We now use a titleblock with a relative link to an Xref for the project information, the title sheet number is linked to the layout tab title, with the rest simple attributes in the sheet.
    The answer is to use the full version - its GATTE command does exactly what is needed. I'm surprised that editing all values of attributes in the drawing can't be done in the LT version.
    Good luck - if you find a solution, please post it up!
    Regards,
    JGA
  1. Replies: 13
    Last Post: 2012-09-18, 07:51 PM
  2. Trying to insert a field in a titleblock attribute
    By jawf in forum VBA/COM Interop
    Last Post: 2009-09-02, 07:50 PM
  3. Change Titleblock Attibutes with vb or vb.net
    By danielsaraiva in forum VBA/COM Interop
    Last Post: 2009-01-31, 09:56 PM
  4. Replies: 4
    Last Post: 2008-12-19, 04:24 PM
  5. Change titleblock without creating a new sheet
    By Exar Kun in forum Revit Architecture - General
    Last Post: 2005-06-21, 04:45 PM
