Are there any meaningful how-to's out on creating a deployment with custom settings for Revit 2013? I see there are some options as far as including custom Revit.ini files and something about a inifile.xml I think. I have no idea how to use or modify that stuff. I *REALLY* want to have all the file locations and everything as part of the deployment so I don't have to go around doing it every time.
Would it be as simple as installing it on my own machine, getting everything set, and then using the INI file on my machine in the deployment?
*edit* I went back and looked at the 2012 Deployment threads, and there was a link posted to this Deployment Creation Utility from Autodesk: http://usa.autodesk.com/adsk/servlet...linkID=9273944
Will there be something similar for 2013 or is this utility already built in with the 2013 deployment creation process?
