Public Sub BX()
Dim bTransMan As DatabaseServices.TransactionManager
Dim bTrans As DatabaseServices.Transaction
Dim bDwg As Document
Dim bBT As BlockTable
Dim bBTR As SymbolTableRecord
Dim bBTE As SymbolTableEnumerator
Dim bBTRr As BlockTableRecord
'Current Document
bDwg = Application.DocumentManager.MdiActiveDocument
bTransMan = bDwg.TransactionManager
bTrans = bTransMan.StartTransaction
Try
'Open the database for Read
bBT = bDwg.Database.BlockTableId.GetObject(OpenMode.ForRead)
bBTE = bBT.GetEnumerator
Dim XrefIds As New ObjectIdCollection
Dim DetXIds As New ObjectIdCollection
Dim DetXId As New ObjectId
Dim ReXIds As New ObjectIdCollection
Dim graphXref As XrefGraph
Dim nodeXref As XrefGraphNode
Dim btrId As Object
graphXref = bDwg.Database.GetHostDwgXrefGraph(True)
For idx As Integer = 1 To graphXref.NumNodes - 1
nodeXref = graphXref.GetXrefNode(idx)
If nodeXref.IsNested Then
Select Case nodeXref.XrefStatus
Case XrefStatus.FileNotFound
btrId = nodeXref.BlockTableRecordId
Dim BTR As BlockTableRecord = bTrans.GetObject(btrId, OpenMode.ForWrite)
BTR.PathName = "C:\1.dwg"
ReXIds.Add(BTR.Id)
Case XrefStatus.Unreferenced
ReXIds.Add(BTR.Id)
Case XrefStatus.Unloaded
ReXIds.Add(BTR.Id)
Case XrefStatus.Unresolved
ReXIds.Add(BTR.Id)
End Select
End If
Next
If ReXIds.Count > 0 Then
bDwg.Database.ReloadXrefs(ReXIds)
End If
While bBTE.MoveNext = True
bBTR = bBTE.Current.GetObject(OpenMode.ForRead)
bBTRr = CType(bBTR, BlockTableRecord)
'Check if block is xref and also resolved and then add its ID to the ObjectIdCollection
If bBTRr.IsFromExternalReference Then
Select Case bBTRr.XrefStatus
Case XrefStatus.Resolved
XrefIds.Add(bBTRr.Id)
DetXIds.Add(bBTRr.Id)
End Select
End If
End While
'Bind xref of collection
Try
'We bind all xrefs of drawing
If XrefIds.Count > 0 Then
bDwg.Database.BindXrefs(XrefIds, False)
End If
For Each DetXId In DetXIds
bDwg.Database.DetachXref(DetXId)
Next
Catch ex As Exception
MsgBox("Error2: " & ex.Message) <-----------------The error displayed is from here.
End Try
bTrans.Commit()
MsgBox("Error1: " & ex.Message)
Finally
bTrans.Dispose()
bTransMan.Dispose()
End Try
End Sub
After I use the scalelist command to reset, it doesn't work. Otherwise, it's fine.
