Thread: corrupt file problems and need help!!!! fast.
    2012-04
    Question corrupt file problems and need help!!!! fast.
    hello,
    My name is Travis and i am a architectural student in Chicago Illinois. i have a mid term presentation due on Thursday and i can't open my file and is receiving the following error megs when i try to open my file. "Data in file North side cycle center3.0037.rvt is corrupt and needs to be manually recovered. 'Please contact Autodesk Support." can anyone pass this on to someone that could help or anyone know what i can do.
    2010-06
    10
    Default Re: corrupt file problems and need help!!!! fast.
    A bit late but are you by any chance upgrading to a newer version of Revit?
    Try clicking on OPEN and check the AUDIT option and select your file, it might be enough to fix it.
    If you have some circular references in your project and try to upgrade the file with a higher Revit version it will encounter this error.
    Easy solution is don't upgrade.
    If you, however, are not upgrading and getting this error you my friend are stuffed (in my experience).
    I could stop if I wanted to Norton_cad's Avatar
    2007-05
    Bardwell Valley, Sydney, Australia
    433
    Look for a backup Rvt file, in the journal sub folder of Revit, on your hard dri
    ve.
    Ohm's Law - Electricity follows the path of least resistance.
    Regards,
    Mark Norton,
    Early Adopter sbrown's Avatar
    2003-05
    Coast to Coast
    4,439
    It looks like he is opening a backup file, see the 0037.
    Scott D. Brown, AIA
    Project Coordinator | Director of Building Information Modeling
    HHCP.com
  1. Corrupt file... HELP!
    By Mikkelebrodersen in forum Revit Architecture - General
    Last Post: 2010-11-29, 10:05 PM
  2. Corrupt File
    By dsw98 in forum Revit Architecture - General
    Last Post: 2008-06-09, 04:50 PM
  3. Problems with a CAD file, can it become "corrupt" ?
    By little_ejay in forum CAD Management - General
    Last Post: 2008-05-27, 07:50 AM
  4. Help with corrupt file
    By warnoe uk in forum ACA General
    Last Post: 2007-04-20, 07:40 AM
  5. Corrupt File
    By Clyne Curtis in forum Revit Architecture - General
    Last Post: 2003-09-02, 03:32 PM
