Thread: Miter panel ends
    2012-02
    12
    Question Miter panel ends
    What's the best way to miter the ends of my precast panels at the corners? Right now I just use a void and subtract it out in the project.
    Thank you.
    Certifiable AUGI Addict cliff collins's Avatar
    2003-09
    St. Louis, Missouri
    3,071
    Default Re: Miter panel ends
    Use a wall reveal; 1st--create a Profile family with a 45 degree wedge shape. Load it into your project, and select it in the Reveal Properties.
    Then use the Reveal tool and specify "vertical" orientation. (assuming the mitered ends are in "plan". )
    Cliff B. Collins, Registered Architect / BIM Specialist
    St. Louis, MO
    2012-02
    12
    Sounds good. Thank you. I will be giving that a try.
    2012-02
    12
    My panels are made with line based generic models. Don't reveals have to be used on walls?
    2003-09
    St. Louis, Missouri
    3,071
    OK--you did not mention that in your original post. Yes--you could use line-based voids and cut geometry.
    Or--you might consider using a curtainwall, and creating custom curtain panels which have the voids/reveals cut out and substitute them for the standard curtain panels.
    Heck--you can even replace the standard curtain panel with a Wall, which could then have Reveals in it! ( never actually tried this one!)
    St. Louis, MO
  1. Miter Detail Component
    By bwagner in forum Revit Architecture - General
    Last Post: 2012-07-26, 03:12 PM
  2. 2012: wall cleanup - miter
    By Bryan Thatcher in forum Revit Architecture - General
    Last Post: 2012-01-30, 02:02 PM
  3. 2012: Need help controlling miter angle
    By allen.hart in forum Dynamic Blocks - Technical
    Last Post: 2011-10-04, 04:48 PM
  4. Skewed beam miter
    By jmctamney in forum Revit Structure - General
    Last Post: 2008-08-13, 04:11 PM
  5. Wall Miter
    By rickbowles1 in forum Revit Architecture - General
    Last Post: 2007-03-22, 12:01 PM
