Thread: Coding help.
    I could stop if I wanted to cadd4la's Avatar
    2001-12
    Newport Beach, CA
    399
    Default Coding help.
    Hello everyone,
    I need some help to get this code to work.
    I am looking for it to allow me to select a layer and then make it nonplot.
    After I run it, I get this in the command line "Pick the layer to make nonprint: ; error: too many arguments" and the layer that I have pick has not be set to nonplot.
    (DEFUN C:NP ()(SETVAR "CMDECHO" 0)
            (setq ent_name (car (entsel "\nPick the layer to make nonprint: ")))
        (setq ent_list (entget ent_name))
        (setq l_name (cdr (assoc 8 ent_list)))
        (setvar "-LAYER" "PLOT" "N" l_name)
            (SETVAR "CMDECHO" 1)(princ))
    Thanks.
    2010-06
    962
    Default Re: Coding help.
    Just replace this part ...
    (command "-LAYER" "PLOT" "N" l_name "")
    and it is better to localize variables like this ...
    (DEFUN C:NP (/ ent_name ent_list l_name)
    2001-12
    Newport Beach, CA
    399
    Thank for the help and the localize variables reminder.
    I did have the "" in the code before I posted it and it still didn't work.
    KC
    5,719
    ... Building on Tharwat's post:
    (defun c:FOO ( / eName layerName oldCmdecho)
      (if (and (setq eName (car (entsel "\nSelect layer to make \"No Plot\": ")))
               (setq layerName (cdr (assoc 8 (entget eName)))))
        (progn
          (setq oldCmdecho (getvar 'cmdecho))
          (setvar 'cmdecho 0)
          (command "._-layer" "plot" "n" layerName "")
          (setvar 'cmdecho oldCmdecho)
          (princ layerName))
        (prompt "\n** Nothing selected ** "))
      (princ))
    2001-12
    Newport Beach, CA
    399
    RenderMan,
    Thank you, it works great.
    KC
    5,719
    Quote Originally Posted by cadd4la View Post
    RenderMan,
    You're welcome.
  1. Suggested Guidelines for Coding
    By peter in forum AutoLISP
    Last Post: 2015-07-27, 08:06 AM
  2. Coding help
    By cadd4la in forum AutoLISP
    Last Post: 2013-07-08, 10:50 PM
  3. Coding help
    Last Post: 2013-06-21, 05:20 PM
  4. CODING ELEMENTS
    By Steve Hutana in forum Revit - Platform
    Last Post: 2009-08-09, 08:42 PM
  5. Color Coding XYZ in iProperties Tab
    Last Post: 2006-06-14, 04:07 AM
