Thread: split region tied to base constraint
    2005-12
    134
    Default split region tied to base constraint
    trying to add a stone base to a brick/stud wall. i need the stone base to go 2' above the base constraint and allow the bottom of the wall to move with a stepped footing. pretty basic construction method. if i split the region at the 2' mark on the wall it changes material based on the bottom of the wall and not base on the base constraint. any way to lock it to the main floor finish floor level rather than the bottom (stepping footing)level.
    Certifiable AUGI Addict cliff collins's Avatar
    2003-09
    St. Louis, Missouri
    3,071
    Default Re: split region tied to base constraint
    Try using Edit Profile on the wall.
    I don't think you can do what you are asking with the Wall Properties>Edit Structure>Split Region tools.
    Cliff B. Collins, Registered Architect / BIM Specialist
    St. Louis, MO
  1. Roof & Ceiling Base Level Constraint vs. "Real" Framing
    By jeff.77718 in forum Revit Architecture - General
    Last Post: 2011-01-18, 11:55 PM
  2. Revit Bug? - Split object randomly inherits properties of a split region within it
    By Andrew Dobson in forum Revit Architecture - General
    Last Post: 2010-04-07, 12:23 PM
  3. HSS Hollow Columns not working with base level constraint
    By brinddd in forum Revit Architecture - General
    Last Post: 2010-01-25, 06:59 PM
  4. Base and Top Constraint in Generic Family
    By michael.loistl in forum Revit Architecture - Families
    Last Post: 2009-07-06, 07:12 PM
  5. Base Constraint
    By mmaxwell in forum Revit Architecture - General
    Last Post: 2007-07-20, 02:07 PM
Tags for this Thread
