Thread: Changing circuits, wires don't update
    2011-10
    3
    Default Changing circuits, wires don't update
    I have to do some re-circuiting of my lights. When I edit the circuit of some lights, the wires connected to the lights do not update to the new circuit. So the home-run arrows now show 2 circuits. I have even tried to delete all the wires are do both the automated wiring with TAB+select, Convert to Wires, or manually adding wires myself. In either case, some wires get updated and some don't. Some home-run wires loose their arrows because they loose the circuit.
    Any way to update wires after changing circuits. Any specific way I should be doing the re-circuiting. My method was to select the items I needed to re-circuit, disconnect panel, edit circuit, remove from circuit, select panel. This would create a new circuit from the next available breaker as expected.
    Broomall, Pennsylvania
    25
    Default Re: Changing circuits, wires don't update
    We have run into similar problems. Have you tried removing the wires that need to be deleted first, before editing the circuit and adding or removing lights? That has worked for us.
  1. 2015: Wires picking up differnet circuits.
    By jacob696975 in forum Revit MEP - General
    Last Post: 2015-06-30, 03:15 PM
  2. 2013: changing number of wires to 5 on a panel
    By davel.254027 in forum Revit MEP - General
    Last Post: 2013-01-25, 04:48 PM
  3. Circuits Changing Location on Panel
    By jason.combs in forum Revit MEP - General
    Last Post: 2009-02-19, 09:06 PM
  4. Changing names of circuits
    By rob.goetze in forum Revit MEP - General
    Last Post: 2008-10-29, 11:25 PM
  5. Methods to update Blocks as they are constantly changing
    By jalexander.108656 in forum AutoCAD General
    Last Post: 2006-10-23, 09:19 AM
Tags for this Thread
