Thread: [Help] AEC Walls disappear in 2d, Appear in 3d. Sometimes.
    2010-06
    5
    Unhappy [Help] AEC Walls disappear in 2d, Appear in 3d. Sometimes.
    I'm working on a multi-level residential building in AutoCAD Architecture 2012. The construct I have open is set to be around 9' above grade.
    I'm having some trouble with my custom walls (as well as the pre-defined walls). I have line drawings from a client of the exterior walls. I'm adding interiors using AEC walls. Unfortunately, they oftentimes disappear if I draw them starting at one of the exterior (line) walls. Sometimes it doesn't even matter. Strangly, I can't see them from a 2D view, but a 3D view causes them to show up. I suspect there are certain "zones" that cause this disappearance.
    I clearly have a lot to learn. Can anyone help me out with this? And point me in the right direction for further learning?
    Follow link for visualization of my issue.
    http://i57.photobucket.com/albums/g2...econfusion.png
    2003-03
    Philadelphia, PA
    2,392
    Default Re: [Help] AEC Walls disappear in 2d, Appear in 3d. Sometimes.
    6" As mentioned in your post in the Autodesk Discussion Groups, if you are using Project Navigator, the expectation for a single-level Construct is that its floor level will be at Z = 0 in the Construct file, and Project Navigator will manage the Z-values when assembling multi-level Views. If the (2D?) line drawing was inserted with the Z-value at 9'-0" and you are snapping to that linework without locking Z-coordinates to 0, then you are drawing those Walls with a baseline at Z = 9'-0". If your cut plane is at a typical value (somewhere around 3'-6" above the floor level), then those Wall will be above the cut plane and will not display.
  1. 2011: Walls disappear in ACA Animation
    By rkc in forum ACA General
    Last Post: 2013-02-04, 04:43 PM
  2. 2012: Walls disappear when exporting to .dwg
    By dirks.ryan144049 in forum Revit Architecture - General
    Last Post: 2013-01-17, 04:00 PM
  3. ACA 2008 - walls disappear
    By htlmv in forum ACA General
    Last Post: 2012-06-13, 03:39 PM
  4. Walls Disappear?
    By Tyveka in forum NavisWorks - General
    Last Post: 2009-06-17, 01:17 PM
  5. Why the walls disappear?
    By ricardo.o.maciel in forum ACA General
    Last Post: 2006-04-07, 11:21 AM
Tags for this Thread
